Top 5 Ways to View and Edit Metadata (Practical Guide + Real Examples)
14 min read
DAM for metadata
As digital libraries grow, filenames and folders stop scaling. Teams need clear, consistent ways to view and edit metadata to keep assets searchable, reusable, and properly governed.
This article walks through the most effective methods for viewing and editing metadata, with examples drawn from organizations managing thousands of assets daily.
What Metadata Actually Is (and Why It Matters)
Metadata is essentially “data about your data.” It describes your files in a structured way so that both teams and software can understand what each asset contains and how it should be used.
Instead of relying on filenames like IMG_5402_final_v3.jpg, it adds meaningful context, such as:
  • who created the asset
  • when and where it was produced
  • what it contains
  • what project it belongs to
  • whether it’s approved, restricted, expired, etc.
Types of Metadata Specifications
From our work with teams of all sizes, we see that misunderstandings about EXIF, IPTC, and XMP are one of the biggest causes of metadata inconsistency. Different tools read and write different fields, which is why a file can look “empty” in one viewer and full in another.
For example, a photo taken on a camera, edited in Photoshop, and then uploaded to a cloud drive may carry three different sets of metadata: some overlapping, some missing.
So, let’s clarify what’s going on through a quick overview of the main metadata standards:
Specification
What It Is
What Includes
Best For
EXIF
(Exchangeable Image File Format)
Automatically written by cameras and mobile devices
Camera model, exposure, date/time, GPS, technical settings
Technical context and sorting by capture details
IPTC
(International Press Telecommunications Council)
Industry standard for describing image content
Keywords, titles, descriptions, creator, copyright, location names
Searchable, descriptive information
XMP
(Extensible Metadata Platform)
Adobe’s modern, flexible metadata framework
Everything IPTC can store + structured custom fields
Consistent metadata across tools; complex workflows
Embedded Metadata
Metadata written into the file itself (EXIF/IPTC/XMP)
Varies by format
Portability and long-term archiving
Custom Metadata Fields
(DAM-specific)
Created inside the DAM to fit a team’s workflow
Project ID, approval status, license expiration, department, usage notes
Internal collaboration, workflow management
Once you know how these pieces fit together, it becomes much easier to manage metadata effectively, and to choose the right tools for keeping it consistent across your entire library.
💡 If you’re exploring how to structure large image libraries around these standards, here’s a deeper dive into organizing visual archives
Top 5 Ways to View Metadata
These are the methods teams use most often, from the fastest checks to advanced professional workflows.
1. View Metadata in Windows Explorer (Quick & Built-In)
This is the fastest method when you need a quick overview of basic data such as camera settings or file dimensions.
How to view: Right-click the file → Properties → Details
You’ll see:
  • Dimensions
  • Camera EXIF
  • Capture date
  • Author (if available)
Limitations:
  • No IPTC or XMP
  • No batch view
  • Not suitable for large libraries
Viewing metadata in Windows
2. View Metadata in macOS Finder
How to view: Select a file → Command + I (Get Info).
You’ll see: A simple set of EXIF details.
Limitations:
  • IPTC/XMP aren’t shown
  • Only basic info is available
  • Hard to use for volume work
Viewing metadata in macOS Finder
3. View Metadata in Photo Tools (Lightroom, Photoshop, Bridge)
Most creative tools have built-in metadata panels.
How to view: Open the file → find the Metadata, Info, or Properties panel.
You’ll typically see:
  • EXIF
  • IPTC keywords
  • Captions and descriptions
  • Copyright
Limitations:
  • You need to open files individually
  • Different tools map metadata differently
  • Not ideal for managing thousands of assets
4. View Metadata with ExifTool (for Power Users)
ExifTool exposes everything inside your file, even hidden fields.
How to view: Run ExifTool in the terminal (macOS/Linux) or Command Prompt / PowerShell (Windows).
You’ll see:
  • Full EXIF data (camera, exposure, GPS, device info)
  • IPTC fields (keywords, captions, creator, copyright)
  • XMP properties
  • Technical and hidden fields not visible in GUI tools
  • Format-specific metadata (for video, audio, PDFs, RAW files)
Limitations:
  • Command-line interface
  • Not designed for teams or non-technical users
Viewing metadata in ExifTool
5. View Metadata in a DAM System (Daminion)
A Digital Asset Management system provides the most complete, consistent view of metadata across all file types: images, videos, documents, audio, PDFs, and more.
Viewing metadata in Daminion DAM
How to view: Open the asset inside the DAM interface and select it. Metadata is displayed in a dedicated panel alongside the preview and can be viewed for one file or hundreds at once.
You’ll see:
  • EXIF data (capture details, device information, GPS)
  • IPTC fields (keywords, titles, descriptions, creator, copyright)
  • XMP metadata
  • Video codecs and technical video properties
  • Audio metadata
  • Office and PDF metadata fields
  • Custom metadata fields defined by your organization
Limitations:
  • May require some initial setup and structure planning
  • More powerful than simple viewers, which may be unnecessary for very small libraries
Still Deciding?
Try our DAM solution free and see how it fits your team’s daily workflow — no pressure, just thoughtful help from experts.
Top 5 Ways to Edit Metadata: From Simple to Professional
Once you know how to view metadata, the next step is keeping it clean and consistent across your entire library.
Below are the five most common ways teams edit metadata — from basic OS tools to professional solutions used in creative, marketing, public sector, and production environments.
1. Edit Metadata in Windows Explorer (Basic Edits Only)
How to edit: Right-click the file → Properties → Details → Click the fields you want to change.
What you can edit:
  • Title
  • Subject
  • Comments
  • Some author fields
  • Remove metadata: Use “Remove Properties and Personal Information.”
Limitations:
  • Only a few IPTC fields are editable
  • No XMP editing
  • No batch editing
  • Easy to create inconsistencies if multiple people do it differently
Editing asset tags and comments in Windows
2. Edit Metadata in macOS Preview (Privacy-Only Editing)
macOS offers almost no native tools for editing descriptive metadata, but it does allow you to remove certain privacy-sensitive fields.
Remove location data: Open the image in Preview → Tools → Remove Location Info
Limitations:
  • Cannot edit IPTC or XMP metadata
  • Cannot add keywords, descriptions, copyright, or usage rights
  • No batch editing
  • Not suitable for cataloging or workflow-based metadata management
macOS essentially offers a metadata remover, not a metadata editor.
Editing asset tags in macOS Finder
3. Edit Metadata in Photo Tools (Lightroom, Photoshop, Bridge)
Most creative teams start here because the tools are familiar. But it’s not ideal for organization-wide metadata consistency.
How to edit: Open the file (or select multiple files) → go to the Metadata / Info / Keywords panel
What you can edit:
  • IPTC keywords
  • titles and descriptions
  • Copyright and creator info
  • Basic XMP metadata
Limitations:
  • No controlled vocabulary → inconsistent tags
  • Easy to overwrite each other’s metadata
  • Not ideal for large digital archives
  • Limited governance or permissions
4. Edit Metadata with ExifTool (Advanced, Technical Editing)
ExifTool can modify any IPTC/XMP/EXIF field across huge sets of files.
How to edit: Run ExifTool commands in the terminal or command prompt to write → Update or remove specific metadata fields for one file or many files at once
What you can edit:
  • EXIF metadata (camera data, dates, GPS, technical fields)
  • IPTC metadata (keywords, titles, descriptions, copyright)
  • XMP metadata and custom namespaces
  • Format-specific metadata for images, video, audio, and documents
Limitations:
  • Requires technical expertise to use safely
  • High risk of large-scale mistakes if misused
  • Not sustainable for ongoing, day-to-day team workflows
5. Edit Metadata in a DAM System (Daminion) — Most Scalable Method
A Digital Asset Management (DAM) system brings structure, consistency, and governance to metadata workflows for teams across industries.
Unlike OS tools or creative apps, which show only a portion of embedded data, DAM tools like Daminion handle all major metadata standards in a unified place.
Editing asset description in Daminion
How to edit: Select one or multiple assets in the DAM interface → Edit metadata in a dedicated panel → apply changes instantly or write them back to files via XMP
What you can edit:
  • Batch-edit metadata across thousands of assets
  • Apply controlled vocabularies to prevent typos and duplicates
  • Write IPTC/XMP metadata back into files
  • Control who can edit metadata with role-based permissions
  • Add custom fields for clients, approval status, campaigns, or departments
  • Enrich assets with AI-generated tags
  • Track versions and restore previous metadata states
Limitations:
Metadata can only be edited in fields that are set up in advance, so everyone follows the same rules and information stays consistent.
Comparison: How Common Tools Handle Metadata
Before we move on to the next chapter, let’s look at the basic definitions of metadata types:
Tools
How to View metadata
How to Edit metadata
Limitations
Best Fit
Windows Explorer
File properties → Details
Edit basic fields in Properties
Very limited fields, no batch editing
Quick checks, one-off edits
macOS Finder
Finder (Get Info) or Preview
Remove location data only
No IPTC/XMP editing
Viewing metadata, privacy cleanup
Metadata or Info panels
Edit fields per file or selection
Easy overwrites, no governance
Creative production workflows
ExifTool
Command-line output
Command-line commands or scripts
Not usable for teams
Technical cleanup, migrations
Centralized metadata panel
Batch editing via controlled fields
Depends on file format support
Efficient team workflows and large libraries
Real-World Metadata Wins
After working with more than 800 organizations across architecture, higher education, cultural heritage, and creative production, our Daminion team sees the same metadata challenges appear again and again: inconsistent IPTC fields, overwritten keywords, scattered archives, and unclear usage rights.
Here are three real examples that illustrate how structured metadata transforms day-to-day work:
1. Environmental Management (West Gippsland CMA)
West Gippsland CMA works with thousands of photos from field inspections, flood events, and environmental monitoring, all stored locally. Before Daminion, images were saved with inconsistent names and without a clear metadata structure. Staff often had to browse folders manually, and finding a single photo could take hours, sometimes even days.
With Daminion, the team introduced structured metadata and GPS fields, linking photos directly to maps and GIS tools. Images can now be searched by location, category, or keywords, even visually from a map interface.
“Before Daminion, our staff could waste a whole day looking for one photo. Now they spend two minutes on it.”
Cate Reilly
Business and Systems Analyst at West Gippsland CMA
2. Architecture Studio (Leroy Street Studio)
Leroy Street Studio had accumulated decades of architectural photos, drawings, PDFs, and presentations. These files were stored in folders and managed with basic tools that offered limited search and categorization. As a result, architects often searched online instead of reusing internal project references.
After implementing Daminion, the studio created a custom metadata structure tailored to architectural workflows, covering projects, styles, and document types.
“We needed something robust yet easy for everyone in the office to use. With Daminion, it’s simple to find and export files.”
Laura Reneke
Production Manager at Leroy Street Studio
3. Creative Production Studio (Floyd County Productions)
Floyd County Productions, an animation studio best known for long-running TV series, manages an archive containing millions of production files created over many years. Before Daminion, artists relied on an internally developed tool that became increasingly difficult to maintain, making it harder to locate reference assets from past seasons.
With Daminion, the studio turned its existing file and folder structure into usable metadata. Instead of manual tagging, the system reads structured file names and directories, allowing artists to search for characters, poses, outfits, and props across seasons without changing their workflow.
“If it’s something we’ve drawn before but can’t recall where, Daminion can save hours of work.”
Ethan Sting
Technical Director at Floyd County Production
Make Metadata Work for Your Team
Metadata is what makes a digital library usable, but only if it’s searchable, consistent, and aligned with how your team actually works.
Basic tools (Explorer, Finder, Lightroom) work well for simple tasks, but once your library grows and more people rely on it, a centralized metadata workflow becomes essential.
A DAM system like Daminion keeps metadata accurate across your entire library and gives your team a fast, reliable way to find, edit, approve, and reuse assets. If you’re ready to see how this could look for your team, book a short demo with Daminion to see efficient metadata management in action.
