Using tags to classify the media library quickly
2 min read
It’s impossible to avoid human input when classifying media documents. It’s possible for text and audio files, but not for images and videos. Daminion can extract all the technical information from the files, but you will need to manually describe the content of your pictures and videos:
  1. Who is showing in a picture
  2. What is showing in a picture
  3. Where was picture taken (This can be partially solved by using GPS info)
  4. What place is shown in a picture?
  5. What event is depicted in the picture?
  6. Who are the document creators (third-party images often
    come with some copyright info on IPTC that can be easily
    detected and imported by Daminion)
Using tags drastically reduces the time needed to classify documents. Daminion includes about 30 predefined tags that can be shown on the tag panel; that is usually enough in most cases. Some tags examples are: Creation Date/time, File Folder, Author, People, Event, Keywords, Categories, Featured Place, Rating, Color Label, Camera, Lens, and Media Format. A bit later, we’ll add the ability to create and assign custom tags. For example, tags for a Construction Company could be: Device, Department, System, and Chassis.
Tags can be organized with no limitations on nesting depth! You can create highly complex category structures or simple ones. It is up to you and depends entirely on your requirements and not on any program limitations. Most importantly, your tags can be saved to XMP preserving the hierarchy. Any program that understands XMP and hierarchical tags can restore your tag structure.
hierarchical-catalog-tags
Existing tags can be assigned to Documents by dragging and dropping. New keywords are created from the context menu and you can add multiple keywords at once, separated by commas. Some system tags like Rating, Media Format, Camera, and Folder cannot be changed.
multiple-tag-creation
The “Shown Place” tag is composite and contains 4 named levels:*
  • Country,
  • State,
  • City
  • Location
Each level is mapped to separate IPTC/XMP metadata field. * We’ll probably add a 5th level named “Region” according to XMP specification.
create-a-new-place-tag
Below is the prototype of the Quick Assigner window that is not yet implemented. It will provide quick access to recently assigned tags.
quick-tag-assigner
