Sometimes the most important updates aren’t the ones you see — but the ones that quietly improve everything behind the scenes. With Daminion 10.3, we’ve made your everyday work a little easier, a little faster, and a lot more stable. This update isn’t about new buttons or bold redesigns; it’s about quiet, meaningful improvements that help you stay focused on what matters.
And it’s just the beginning. These upgrades are laying the foundation for something much bigger: our upcoming shift to a fully unified Daminion platform across Windows, Linux, and the Cloud.
Powered by PostgreSQL 17
Daminion now supports the latest PostgreSQL 17 — bringing greater speed, security, and reliability to your asset management operations.
- Faster application response, even under heavy loads
- Improved database security for peace of mind
- More stable daily operations with fewer interruptions
🛠 New installations include PostgreSQL 17 by default. 🧩 Upgrading? Our support team is here to help with a smooth transition. |
Easier Management of Large File Imports
Importing 20,000+ files? You’ll now get a prompt to use automatic folder scanning, making large imports faster, easier, and more reliable.
Let your team skip the waiting and start working right away.
Desktop & Server Improvements
We’ve fine-tuned Daminion where it matters most:
- Optimized high-DPI display support on Windows 11
- Hidden system files and folders are now skipped during import
- Improved database operations for better efficiency
- File status is now updated automatically — keeping your archive accurate
- Backend upgraded from .NET 6 to .NET 8 for modern performance
What’s Been Improved
A number of pesky bugs have been resolved in this release:
- Emails sent via MAPI now work reliably
- PDF exports (even vertical ones) are now rendered properly
- File orientation detection is accurate across formatsEPS previews are clearer and higher-res
- EPS previews are clearer and higher-res
- AD group renaming no longer causes sync issues
- Thai text now searchable in QuickSearch
- SVG handling is more stable
- Color profiles now consistently match source files
Building Toward the Future
This release is more than just a performance boost — it’s a step toward our broader vision for Daminion.
We’re gradually unifying the platform to support Windows, Linux, and cloud deployments, giving teams the flexibility to work in any environment.
At the same time, we’ve begun rolling out project-based workflows to bring greater clarity, structure, and collaboration to your asset management process. And this is just the beginning — more enhancements are already on the way.
Thanks for choosing Daminion — and stay tuned as we continue to evolve the product, making it even more powerful, flexible, and user-friendly.
💬 Need Help Upgrading?
Our team is here if you need support with the upgrade process.
