How to Decrease Storage Fees for Online DAM/File Storage Systems
Are your online storage fees creeping higher than expected? Do you struggle to manage storage costs effectively? How can you optimize your file storage without losing access to critical assets?
With the growing reliance on digital asset management (DAM) and file storage systems, many organizations face rising costs as their storage needs expand. Fortunately, there are several strategies to reduce these fees without sacrificing efficiency or access to vital assets. Let’s explore the best ways to minimize storage costs while maintaining a streamlined file management system.
Worried About DAM Storage Costs?
Best ways to minimize storage costs while maintaining a streamlined file management system
Potential Solutions to Minimize Asset Storage Costs
1. Remove Duplicate Files by Sorting by Size
Duplicate files are one of the biggest contributors to unnecessary storage costs. These copies not only clutter up your system but also take up valuable space that could be put to better use. Sorting files by size makes it easier to identify and remove duplicates, especially for large video, image, or design files commonly stored in DAM systems.
2. Backup Rarely Used Files
Not all digital assets need to be easily accessible at all times. For files that are rarely used—such as archived projects, outdated marketing materials, or legacy documents—consider moving them to a less expensive, long-term storage solution.
3. Use an On-Prem (Local) System
For organizations with extensive asset libraries, an on-premises (on-prem) solution can significantly reduce costs over time compared to constantly paying for online storage. On-prem solutions give you full control over your storage infrastructure and eliminate monthly fees associated with cloud services.
4. Compress Large Files
Large media files such as high-resolution images, videos, and graphics tend to occupy the most space in DAM systems. Compressing these files reduces their size without losing significant quality, thus saving storage costs.
5. Regularly Clean Up Unused or Outdated Assets
Over time, digital libraries accumulate outdated or unused assets. Whether they are old branding materials, expired licenses, or redundant documents, these files add to your storage costs.
6. Implement a Tiered Storage System
A tiered storage system allows you to store frequently accessed assets in higher-cost, fast-access storage, while less-used assets are moved to more affordable, slower storage tiers. This strategy optimizes both accessibility and cost efficiency.
7. Enforce Strict Version Control
Multiple versions of the same asset can quickly fill up storage. While it’s important to keep previous versions of assets for backup, uncontrolled versioning can lead to storage bloat.
Conclusion
Reducing storage fees in online DAM and file storage systems is all about smart management. From removing duplicates and compressing files to implementing tiered storage systems and leveraging on-prem solutions, there are numerous strategies to optimize your storage.
By regularly auditing your digital assets and using efficient file management practices, you can control costs without sacrificing access to your critical data.
Getting Started with Daminion
