Home » Documentation » Web Client » Customizing the Web Client Interface
Settings Window
Color scheme: Set up a color scheme here for the current catalog  and a default color scheme for all catalogs . Select between light and dark themes, change the accent color that is used to highlight tag headings in the Properties panel, checkmarks, Save icons etc. You can also choose a logo for the current catalog or for all catalogs.
Logotype: Upload a default logo  for the web catalogs here. Click Choose file and select a file from supported format (PNG, SVG, JPEG), logotype will be automatically resized to 200×90. If necessary, change the default logo for a unique logo for this catalog only. When logging in to other catalogs, users will see the default logo.
Select a language for the currently logged-in user and for all other users. You have a choice of English,Russian,Deutsch,Nederlands,Espanol,Francais,Italiano.
Note: The settings displayed above are available for users with admin access rights only. By default, Editors, Viewers, and Guests are only able to change the catalog language. Other users’ permissions can be extended via Daminion server admin panel > Administration > Roles
Login Page: Customize your login page here . Select a background image and a logotype for the intro page, as well as define the welcome message.
Drag and Drop: Here you can enable or disable the drag hint.
